| Hi all. Anyone here in SA got 1 spare pushrod.
Is ball n ball type. Big ball one end.... smaller on other end. 218mm length. Or 8.575inch. 8mm diameter of shaft.
Will buy. |
https://www.ebay.com/p/Engine%2DPush%2DRod%2DStock%2DMelling%2DMPR%2...
Or this:
http://store.440source.com/Stock-Replacement-Pushrod-B-New-Single/p...
Edited by mstrug 2018-07-25 5:19 PM
| I got one...... sourced locally in SA...... about half a mm shorter......seems to do the job. I now have oil pressure again. Thanks for replying tho. |
Location: WHEELING,WV.>>>HOME OF WWVA | so, what you found was an 8.555 pushrod? -------------------------------------------------------------later |
| Yeah... found pushrods for the low block 383. 8.575x5/16 they do the job. |
