Powerflite Transmission ID 1956 Fireflite
RDP3430
Posted 2018-06-03 9:18 PM (#564507)
Subject: Powerflite Transmission ID 1956 Fireflite
I pulled an engine/transmission out a of 56 Desoto Fireflite.....curious on the trans if it the original. Number on it is 1638292. Then there is a "D" - H - 18- 55
Anyone have a parts book to identify it ?
Not sure if the 18 - 55 is a date code hence me asking. Different rebuild kits between an early 56 and a late 56.
Thanks,
Rick
Posted 2018-06-03 10:46 PM (#564508 - in reply to #564507)
Subject: RE: Powerflite Transmission ID 1956 Fireflite
500020002000500100100100100
Not sure if that is the correct PN. I get 1636 237 (and see Notes 3 and 4):
Edited by 56D500boy 2018-06-03 10:47 PM
(56PowerFlitePNs.jpg)
Attachments 56PowerFlitePNs.jpg (159KB - 120 downloads)
RDP3430
Posted 2018-06-04 7:15 AM (#564515 - in reply to #564507)
Subject: Re: Powerflite Transmission ID 1956 Fireflite
Yep....that was the closest I got (have the parts book.) could not find 1638292. thanks.
Posted 2018-06-04 8:09 AM (#564517 - in reply to #564515)
RDP3430 - 2018-06-04 7:15 AM
I use the electronic (pdf) version of the 1955-58 Mopar Parts book and I did a search on 1638 292 and nothing came up in the 1268 pages of the book.
Edited by 56D500boy 2018-06-04 10:48 AM
RDP3430
Posted 2018-06-04 10:06 AM (#564522 - in reply to #564507)
And the casting number is 1633721-2. Thanks.
Posted 2018-06-04 10:48 AM (#564526 - in reply to #564522)
RDP3430 - 2018-06-04 10:06 AM
Searched the 1268 pg pdf and as expected 1633 721 didn't show up. Casting numbers almost never do.
Good luck with the hunt.
RDP3430
Posted 2018-06-04 9:13 PM (#564547 - in reply to #564507)
Thanks....I have a another 56 Fireflite I am restoring...will see what the numbers are on that one. Hopefully the numbers will be in the parts book...thanks.
Did see on another site someone had a powerflite for sale out of the 56 Plymouth (air cooled) cast number was 1633721-1....go to be a sheet with cast numbers somewhere....
Fireflite56
Posted 2018-06-04 10:12 PM (#564556 - in reply to #564507)
10010010025
The 1956 DeSoto Fireflite Sportsman I am restoring has the same number. I have several others I can check as well if I can think of it.
(IMG_2784a.jpg)
(IMG_3010a.jpg)
Attachments IMG_2784a.jpg (148KB - 123 downloads)
Attachments IMG_3010a.jpg (178KB - 122 downloads)
