Location: lafayette,La. | Looking for the starting button that fits on the transmission selector switch. It is part # 1843420. Thanks For any help. Jerry
(DSCN0064.JPG)
Attachments ---------------- DSCN0064.JPG (182KB - 48 downloads)
Location: So. Cal | These start buttons are not very reliable. I am wondering if there is an easy way to convert a modern switch to work there instead. I get tired of tearing the dash apart to make it work again. |
Location: lafayette,La. | Yes right now I have a button below the on/off switch I am using. Thanks Jerry |
Location: So. Cal | Yeah, I did the same thing with my '58 Coronet, but I would like to setup something that will work with the neutral button eventually. |
Location: Ontario, Canada | OR-- change it to a key start. Use an ignition switch off a Ply.
Greg |
Location: So. Cal | Too boring. Every other car has that! |
