Location: So. Cal | I purchased this NOS tail lamp for my '58 Dodge, but I don't recognize the part that is bolted to the back side of it. But it does fit the size and bolt pattern so it makes me believe that it was at least made to fit this tail lamp bezel. Does anyone recognize it? Maybe for a foreign car application that used the Dodge bezel?
(Taillamp Ext Frontside.jpg)
(Taillamp Ext Backside.jpg)
Attachments ---------------- Taillamp Ext Frontside.jpg (188KB - 109 downloads) Taillamp Ext Backside.jpg (182KB - 137 downloads)
Location: Lower Mainland BC | Powerflite - 2018-05-07 11:40 AM
We've been through this recently. Its for a 58 Dodge Suburban:
REFERENCE: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=67683&...
Edited by 56D500boy 2018-05-07 11:47 AM
Location: So. Cal | Thanks Dave. A wagon application makes a lot of sense. |
Location: Lower Mainland BC | mstrug - 2018-05-07 1:19 PM Sweptside too?
Yeh, probably because the Sweptside used suburban overlay fenders. It's all about the angle.
The sedans (and covertibles) had a vertical taillight base, but the wagons and the Sweptsides were on an angle, hence the extra bezel.
Location: Newark, Texas (Fort Worth) | Yes, the 1958 Sweptside received 1958 Dodge Wagon Taillights, and '57s got '57's. 1959's got...
Edited by mstrug 2018-05-07 4:29 PM
(1959sweptside.jpg)
Attachments ---------------- 1959sweptside.jpg (245KB - 103 downloads)
Location: So. Cal | It looks like the upper and lower are different from each other. I'll have to figure out which one I have. I don't see a part number on it, but maybe I will if I remove it from the tail light. |
Location: So. Cal | I was wrong. They are the same part top and bottom when you look up the references.
Edited by Powerflite 2018-05-07 5:56 PM
Location: Kennewick Wa | The extension is the same for all 3 years... |
