Location: Northern Illinois | hi everyone, new to the site but long time mopar enthusiast. just acquired an 1955 dodge custom royal 4 door. car is complete and not in too bad of shape. only thing missing is the engine. im in northern Illinois looking for a 270 ci. hemi engine for a REASONABLE price, doesn't have to run but rebuildable. if anyone knows where one might be, please let me know. thank you in advance!!!! |
Location: Lower Mainland BC | hondaman1974 - 2018-03-08 9:44 AM
Welcome to the forum. You could post photos of your car to get us more interested.
Some hints on posting photos are found here:
http://www.forwardlook.net/forums/forums/thread-view.asp?tid=64340&...
As for the engine, you are correct that a 270 hemi is the correct engine for a 55 Custom Royal. However, the reality is a) you might not find one and b) a 4 dr sedan is never going to command big bucks, even if it was restored to the 9's. As a result, you might consider installing a non-55 engine, including the 56 D500 315 hemi or a 57 D500 325 hemi. OR if that didn't work out, a more modern non-hemi Mopar engine, anywhere from a 318 LA to a 440. With the more modern engines you could also go with 12V negative ground and an alternator instead of a 6V positive ground generator.
I have 56 Custom Royal 4 dr sedan and I am a realist about its ultimate value being less than any 56 Lancer.
REFERENCE: http://www.lov2xlr8.no/brochures/dodge/55dg/55dg.html
Edited by 56D500boy 2018-03-08 10:48 AM
Location: Northern Illinois | thanks 55d, would like to keep it as original as possible (kind of a fanatic on that), in doing some online research im finding some engines but may have to buy the whole car. I have a few thing to do to it before I start seriously looking for one. I would like to switch to 12v but might start with 6v and convert later. ill get some pictures posted asap for you guys to check out!!! |
Location: So. Cal | You really should include your location in your profile. Not knowing if you are in Hawaii, Finland, Alaska, Sweden, Australia or Iowa makes a huge difference whether people will respond to you about a motor for sale. |
Location: So. Cal | This '56 315 hemi motor came up for sale.
https://www.ebay.com/itm/263539046914?ul_noapp=true |
Location: Lower Mainland BC | Powerflite - 2018-03-09 10:29 AM
Yikes!! $4550 BIN price.
Seller's story isn't 100% accurate: "A stock 1956 Dodge D500 sedan smashed 306 speed and endurance records in a 14-day run at Bonneville, Utah."
Not true. It was the 230 hp 4 bbl dual exhaust 315 Poly that was used for the record setting.
The record run was done in Sept. 1955 well before the D500 hemi was made available.
Location: N.W. Fla. | Engines come up on EBay, Hot heads, & the HAMB's, classifieds. |
Location: Peoples Republic of Oregon | I'll suggest that the seller on ebay is a rapist; take some vasoline with you....
A rebuildable core, IMHO, whether a 241-260-270, should be in the $600-$800 range depending on level of completeness. The 315/325 could add $500-$700. Some folks will demand
more for the Hemi and some will pay you to haul off a 'poly'. There is no logic that I have found. The poly is every bit as good a performer in stock trim as the Hemi.
Unless you are working toward a 100 point car then any of the Dodge engines would be useful and only a good eye will know what the 'use code' says....... |
Location: So. Cal | You are right that performance-wise, there is no real reason not to use the poly motor as-is. They perform very well and you can get them very cheaply. The reality is that Dodge hemi parts tend to be quite expensive, even if purchased separately. You can get a poly motor and try to convert it, but it isn't going to be cheap doing it that way either. However, I don't think a 315 hemi motor is worth more than $1500 to $2000 max. A 270 hemi is more like $1000. 270 hemi heads, rockers, exhaust, valve covers & tubes will also cost $1000 - the bottom end of the 270 is free. But good luck finding one. They don't seem to have survived as well as the Chryslers. |
