Thompson vs Vickers
bbrasse1
Posted 2018-01-24 6:49 PM (#556876)
Subject: Thompson vs Vickers
50025
Is the Thompson pump better than the Vickers pump? I have three Vickers pumps 57-58 Desoto and yet I see Thompson pumps on the same years on some Desoto and most Chrysler engines. Any real difference?
Posted 2018-01-24 8:42 PM (#556883 - in reply to #556876)
Subject: Re: Thompson vs Vickers
5000
there are two types of Thompsons. one looks like a revolver chamber the other has a like a spring loaded chamber. The revolver Thompson is not really rebuildable(just a few seals needed) and it the rarest of the pumps I believe. It also looks like if you keep the oil clean it would never wear out. I like the Thompson because they are more compact. The Vickers has that big chamber up top. here is the Thompson revolver type. maybe the Thompson was more expensive than they Vickers? They went back and forth from Vickers and thompsons. http://www.forwardlook.net/forums/forums/thread-view.asp?tid=11168&...
I honestly think the Thompsons are the better quality pumps. I think the vickers is an older style.
Here is the "alternate" later thompson rebuild kit.  You can see it does away with the "revolver" and I would think maybe this is the best Thompson design?  I think they used this design from 57 and up for some years.
Rebuild kits are easy to find and its easy to rebuild.  The revolver thompson only need a few seals at the seal shop. I think the vickers rebuild kits are easy to find also.  I think the vickers design started out in the 40's.
Edited by mikes2nd 2018-01-24 8:52 PM
Posted 2018-01-25 7:02 PM (#556924 - in reply to #556883)
20001000500100100252525
mikes2nd - 2018-01-24 5:42 PM
Not been my experience.
Posted 2018-01-26 12:36 AM (#556941 - in reply to #556876)
5000
you could be right, okay Thompson second gen then
I accidentally bought one of those and had to sell it. Now that I think about it those were everywhere.
The vane type Thompson. The vane type Vickers looks like its out of a model T.
Mopar1
Posted 2018-01-26 10:59 AM (#556954 - in reply to #556941)
2000100025
Thompson is a sub machine gun & the Vickers is a heavy machine gun, oh, wait, never mind...
