1961 Chrysler shift cable
johnfin
Posted 2018-01-01 8:04 PM (#555401)
Subject: 1961 Chrysler shift cable
How hard is it to remove and re-install the shift cable. I have noticed alot of people leaving the cable attached to the transmission when they remove the transmission.
51coronet
Posted 2018-01-01 10:47 PM (#555418 - in reply to #555401)
Subject: Re: 1961 Chrysler shift cable
1001001002525
its a pain simply because you cant see in there to release it
Posted 2018-01-02 1:32 PM (#555452 - in reply to #555401)
Subject: RE: 1961 Chrysler shift cable
20001000500100100252525
Buy the book.
(Shift cable Removal.jpg)
Attachments Shift cable Removal.jpg (181KB - 102 downloads)
Billohio
Posted 2018-01-05 4:24 PM (#555662 - in reply to #555401)
I have the book and still a pain!!!
hemidenis
Posted 2018-01-05 8:55 PM (#555690 - in reply to #555401)
20001000500100100100252525
got to take the oil pan, then it will be very clear.
Edited by hemidenis 2018-01-05 8:56 PM
Posted 2018-01-06 11:29 AM (#555718 - in reply to #555662)
Here's what you're dealing with, the cable end clips into the adapter and is retained by the spring wire; to remove the cable you push in the end of the spring wire to release it.
(Cables&adapters.jpg)
Attachments Cables&adapters.jpg (72KB - 108 downloads)
Posted 2018-01-06 1:41 PM (#555724 - in reply to #555690)
50002000100100100100
hemidenis - 2018-01-05 8:55 PM
correct and you will have to do it anyway to adjust it properly. the fsm procedure works but its never perfectly aligned, the way it should.
