| Will a set of 383 B block "906" heads (from a 1970 Chrysler) work with a 1961 413 in an Imperial? If not, does anyone have a chart/guide to which heads fit which blocks? |
Location: Alaska | The heads will fit just fine on a 413 but the compression ratio will be lower. It will drop from 10 to1 (advertised) to about 9 to 1. You will need to use the 70 rocker shafts and valve covers. |
| Thanks for the advice. My friend traded a 58 Edsel for a 62 Newport and a bought a 383 to swap in, then managed to revive the Newport's 361. He has everything I need to use these heads. Do I need new push rods or will they line up alright? If I need new ones, do I buy 383B pushrods? |
Location: Newark, Texas (Fort Worth) | Chart: http://www.moparts.org/Tech/Archive/motor/36.html
Casting#
Part#
Engine Chamber In Ex
1737637
1944705
2128533
58-59 361 Closed 1.94
1.60
1737637 2448752 60 361/383 Closed 1.94 1.60
2206324
2206924 2128589 61-62 361/383/413 Closed 2.08 1.60
2402286 2402358 62 413 Max Wedge Closed 2.08 1.88
2463209 2406754 63 426 Max Wedge Closed 2.08 1.88
2463200 2448752 63 361/383/413 Closed 2.08 1.60
2406518 2406736 64 426 Max Wedge Closed 2.08 1.88
2406516 2406732 64-67 361/383 Closed 2.08 1.60
2406158 2806019 67 440 Closed 2.08 1.60
2780915 2800762 67 440 HP Closed 2.08 1.74
2843906 2843904 68-70 383/440 Open 2.08 1.74
2951250 2843904 68 440 Open 2.08 1.74
3462346 3462344 71-72 383/400/440 Open 2.08 1.74
3462346 3671640 73 400/440 Open 2.08 1.74
3751213
3751218 73 400/440
Motor Home Open 2.08 1.74
3769902
3769910
74 400/440 Open 2.08 1.74
3769975
3769954
75 400/440 Open 2.08 1.74
4006452
3769954
76-78 400/440 Open 2.08 1.74
http://www.mymopar.com/headcastnumb.htm
RB/B Engine Cylinder Heads Casting Numbers
Casting Number Engine CID Year Intake Exhaust
4021051 360 1977-86 1.88 1.60
1737637 361 1958-59 1.94 1.60
1944705 361 1958-59 1.94 1.60
1737637 383 1960 1.94 1.60
2206324 361/383/413 1961-62 2.08 1.60
2206924 361/383/413 1961-62 2.08 1.60
2463200 361/383/413 1963 2.08 1.60
2406516 361/383/413/426 1964-67 2.08 1.60
2408520 413 1964 2.08 1.60
2402557 413 - 300J 1963 2.08 1.74
2402286 413/426 Max Wedge 1962-63 2.08 1.88
2463209 426 Max Wedge 1963 2.08 1.88
2406518 426 Max Wedge 1964 2.08 1.88
2406158 383/440 1967 2.08 1.60
2780915 383/440 1967 2.08 1.60
2780915 440HP 1967 2.08 1.74
2843906 383/440 1968-70 2.08 1.74
2951250 440 1968 2.08 1.74
3462346 383/400/440 1971-72 2.08 1.74
3462346 400/440 1973 2.08 1.74
3751213 400/440 Motor Home 1973 2.08 1.74
3769902 400/440 1974 2.08 1.74
3769975 400/440 1975 2.08 1.74
4006452 400/440 1976-78 2.08 1.74
https://www.kijiji.ca/v-engines-and-engine-parts/city-of-toronto/195...
Edited by mstrug 2017-11-19 1:47 PM
Not only will the chamber size affect the compression ratio but I believe the bolt pattern at the end of the head changed at some point...affects accessory mounting brackets. |
Location: Alaska | There was a change in the hydraulic lifters from early to late but I think the pushrods will still fit, try them and see. |
| The heads will mechanically fit/bolt on. Always check valve clearance. As stated cr will change. Don't go by blueprint volume, measure or "cc" the volume of the actual heads you plan on using. The 413 should be hydraulic valvetrain, use its pushrods as the heads were used on both B and RB blocks without change. Pushrods for B blocks are shorter as deck is shorter. |
