| Not mine and no affiliation.
Albany, NY Craigslist ad for a 1961 Chrysler 4 door. The seller describes it as a hardtop, but clearly it's a sedan.
I don't know how to do a link, but you can check it out on Craigslist. Needs total restoration but looks complete.
They are asking $3,500. or best offer.
Location: Lower Mainland BC | De55 - 2017-11-15 12:48 PM Not mine and no affiliation.
When you see an advert that you want to link here, go to the top of the screen where the https etc. link lives. Click on the link. Should turn blue. Then right click and copy. Come over to the FL and find the forum you want to post it in. Start your thread and then right click and paste, *THEN* right after the URL you just pasted, press the return key. This will make the link live (It's aliiiiivvve) here.
I just found the advert and did the above:
https://albany.craigslist.org/cto/d/1961-chrysler-windsor-4-door/638...
"Very nice Patina on the car" Sure. I call it surface rust.
I'll add a photo after copying the image location
Edited by 56D500boy 2017-11-15 1:12 PM
Location: Georgia | If it would lay off the Pepsis and large pepperoni pizzas, that should clear up!
Pete |
I have a Very solid 1961 Chrysler Windsor 4 door hardtop that i pulled out of a barn last spring. This car is in very nice shape, been sitting inside on the barn floor for years. It does not run but does turn over, Has the original 383 motor, it is a push button automatic. I believe this car is all original, its all complete, no dents. Very nice Patina on the car, only a couple small spots of rust on the drivers side rear wheel well. Please no trades $3500 or best offer, cash is king. Give me a call anytime no later than 7pm. |
Location: WHEELING,WV.>>>HOME OF WWVA | is the car above the same one listed earlier/can't remember where , that at the time also had a parts car with about the same patina on both . if not , its got a twin ----------------------------------------------later |
| I once bought a complete 1960 Chrysler New Yorker with original white paint that had the same surface rust. The paint was now flat white. Scrubbed it down with Bar Keepers Friend and a surprisingly large amount of the surface rust came off. The before and after was quite noticeable. |
