Powder coating 57 Desoto Adventurer Hubcaps?
hemiviper588
Posted 2017-10-31 11:11 AM (#551397)
Subject: Powder coating 57 Desoto Adventurer Hubcaps?
500
Has anyone tried to duplicate (or come close) the factory gold (anodized at the factory) look by Powdercoating 57 Desoto Adventurer Hubcaps? I wanted to gold anodize them, but due to the stainless inner attached to the aluminum outer dissimilar metals it is impossible without un crimping the hubcap. I have found a very close paint, but I hesitate to go that route.
(3554266396_7c236810be_z.jpg)
Attachments 3554266396_7c236810be_z.jpg (127KB - 107 downloads)
Posted 2017-10-31 1:31 PM (#551402 - in reply to #551397)
Subject: RE: Powder coating 57 Desoto Adventurer Hubcaps?
There are translucent powders available. Maybe one of them would work. You may need to blend a translucent gold with a silver metallic base to get a consistent finish.
I think it will take some experimentation to hit on a formula, but it might be worth trying. Powder coat is relatively inexpensive.
https://www.prismaticpowders.com/colors/P-5139S/TRANSPARENT-GOLD-ITE...
(db_file_img_10426_1200xauto.jpg)
Attachments db_file_img_10426_1200xauto.jpg (84KB - 116 downloads)
springsweptwing
Posted 2017-10-31 3:07 PM (#551410 - in reply to #551397)
100010025
You would need to do a test on a old one, a alloy wheel is a lot thicker than these covers , the heat of baking the powder may damage the cover ?
What about vacuum deposit coating, like they do on plastic parts ?
Edited by springsweptwing 2017-10-31 3:08 PM
Posted 2017-10-31 3:48 PM (#551414 - in reply to #551410)
Aluminum melts around 1200* F, I don't think any powder coat ovens get close to that kind of heat. Maybe half that.
Ceramic coating is a different story altogether. It is made for high temp industrial work.
springsweptwing
Posted 2017-10-31 4:01 PM (#551415 - in reply to #551414)
Subject: Re: Powder coating 57 Desoto Adventurer Hubcaps?
100010025
Not saying they will melt, powder coating oven around 400 f , if they have been repaired they may go out of shape, they are not the strongest of covers, I have around 10 of them and all are bent. That's why I say test one before diving in and ruining a full set.
Posted 2017-10-31 5:16 PM (#551416 - in reply to #551397)
50001000500
Can aluminum be plated with gold?
The aluminum can be zincated, then copper plated, then gold plated. Although gold and copper will interdiffuse at high temperature over time, if the part is not hot the plating should meet your needs. Good luck. A. High phosphorus electroless nickel deposits are non-magnetic unless heated to over 250 °C.
hemiviper588
Posted 2017-10-31 9:03 PM (#551429 - in reply to #551416)
500
Thanks very much for the valuable advice! I have straightened and polished my Hub Caps, so maybe a translucent powder coat would be worth a try. I will need a sample part for tryout...I have a hopelessly bent hub cap that may work for that.
It looks a little naked with no caps...I can't wait to get this project completed!
Edited by hemiviper588 2017-10-31 9:14 PM
(rsz_img_9805.jpg)
Attachments rsz_img_9805.jpg (102KB - 114 downloads)
Mike McCandless
Posted 2017-10-31 11:29 PM (#551443 - in reply to #551397)
1000500100100100252525
Beautiful car
hemiviper588
Posted 2017-11-01 2:19 AM (#551446 - in reply to #551443)
500
Mike McCandless - 2017-10-31 11:29 PM
Beautiful car
Thanks Mike! here are a couple more pics.
(rsz_img_9800.jpg)
(rsz_img_9826.jpg)
(rsz_img_9827.jpg)
Attachments rsz_img_9800.jpg (109KB - 108 downloads)
Attachments rsz_img_9826.jpg (111KB - 109 downloads)
Attachments rsz_img_9827.jpg (100KB - 102 downloads)
springsweptwing
Posted 2017-11-01 2:19 PM (#551454 - in reply to #551397)
100010025
Hi Bill,
just on the off chance, do you know of any of those trunk chrome strips for sale anywhere ?
Thanks Paul.
hemiviper588
Posted 2017-11-01 4:50 PM (#551461 - in reply to #551454)
500
I have four of those somewhere....not a complete set. But in nice shape.
springsweptwing
Posted 2017-11-01 5:59 PM (#551465 - in reply to #551461)
100010025
Hi Bill,
PM Sent,
Thanks Paul
