Location: Buffalo, NY | My 58 Plymouth came equipped with Variable speed wipers and the wiper foot pedal pump activation switch. Does anyone know where to find a wiring diagram for the washer foot pedal switch? Can't seem to find anything in the service manual unless I missed it. |
Location: Lower Mainland BC | You sure that is a switch and not a foot operated pump? |
Location: Perth Australia | I have memories of this with my dodge build, I don't think I fond a wiring diagram either, but it should be pretty much "plug and play"
I think you unplug the wires from the switch to the wiper and the foot switch then plugs in between the wiper and the switch.
My foot switch didn't work at first, I had to pull it apart and clean it
56D500boy It is still a foot operated pump, but there is a switch that mounts above the actual pump that makes the wipers do a sweep when you push the pump.
It does not activate an electric pump, just does the wiper sweep
