Posted 2017-06-19 8:13 PM (#542480) Subject: gasket for gas guage sending unit.
OK, I guess the right thickness gasket is still unavailable as a replacement. Anyone have an extra original in useable condition? tried gluing 2 together w/o success.
Posted 2017-06-22 8:59 PM (#542686 - in reply to #542480) Subject: Re: gasket for gas guage sending unit.
Find a local seal and O ring store. They have hundreds of sizes. I picked up a couple of these O rings local, counter guy has a Dodge Charger and gave me the O rings. I just picked out the one that fit the best and installed it. filled the tank and no leaks !!!!! Helps if you grease up the O ring and the under side of the sender and carefully set it in place. Jerry
