Location: St.Catharines, ON CANADA | Does anyone know how to disassemble a Thompson pump for a new seal kit?? I have the kit ( Edelmann 7897 ) |
Location: Western Colorado | Which Thompson pump is it? What year, make, model, etc? There were several different Thompson pumps.
Pictures?
Bob |
Location: Northen Virginia | I played with this pump and it is an nightmare over-engineered piece of work..The methods are in the shop manual, you also are going to need to make your own special tools.
(IMG_0504b.jpg)
(IMG_0590b.jpg)
(IMG_0617b.jpg)
(IMG_0620b.jpg)
Attachments ---------------- IMG_0504b.jpg (46KB - 301 downloads) IMG_0590b.jpg (49KB - 198 downloads) IMG_0617b.jpg (49KB - 213 downloads) IMG_0620b.jpg (37KB - 201 downloads)
Location: Lödöse | Anyone who knows where to find the cap for this pump?
(lock.JPG)
Attachments ---------------- lock.JPG (72KB - 188 downloads)
Location: Lower Mainland BC | moparwannabe - 2017-11-02 4:06 PM
What you are looking for (I think) is a 1732 990 cap for the 1733 976 Thompson PS pump. No hits on 1732990 via eBay search but this 1945461 looks close:
https://www.ebay.com/itm/NOS-MOPAR-1958-9-POWER-STEERING-PUMP-CAP-MO...
(1733496ThompsonPSPumpPartsDiagram.jpg)
(1733496ThompsonPSPumpApplicationListing.jpg)
(1733496ThompsonPSPumpCapPN1732990.jpg)
Attachments ---------------- 1733496ThompsonPSPumpPartsDiagram.jpg (89KB - 192 downloads) 1733496ThompsonPSPumpApplicationListing.jpg (178KB - 192 downloads) 1733496ThompsonPSPumpCapPN1732990.jpg (241KB - 172 downloads)
It sure looks close enough:) Ill contact the seller.
BR
Mats |
| 65$ for a cap is absurd... talk to Big M.
Many normal caps will fit this also. Mine looks different but I have a 57 |
Location: Muskego, WI | I have rebuild these pumps, what a pain. The "plunger and blocks" arrangement is pretty difficult to get back together, but I found that if I coat the plungers with grease that they'll be "sticky" enough to hold their position while I arrange them and reassemble the "body" and "cap" (as named in the diagram above). |
Location: Lödöse | You are absolutely right there Mike! With the freight to Sweden it is a hilarious sum for a cap:) Ill look elsewhere. |
Location: Branson, MO | There is a company, Lares, that does ps pump rebuilds and has parts. Might check them out - www.larescorp.com
Location: Northen Virginia | try to buy the fuel cap for 57-58-59 Imperial... |
