Location: Lower Mainland BC | Sounds like a nice car. Hope you can share some photos with the forum. Here are some hints how to do that:
56D500boy - 2016-10-22 11:16 AM
Okay. Remember that I am a noobie here and I am just learning how this particular forum works. So this following is just based on my limited experience here.
So....it seems that if you want to have your photos interspersed with text (between the photos), you need to have your photos available on a server somewhere (NOT just your hard drive). Something like Imagur or Picasa.
IF that is the case, you would right click on your jpg photo on that server and copy the image location. Then go to the tab with the FL open with a Post New thread going.
THEN after you typed some text you would paste your photo jpg url between this format:
[img src="your first photo's url"] where [ is actually < and ] is > (that is the html protocol for posting photos)
Then you would type some more text and repeat with the second jpg url, and so on
[img src="your second photo's url"] where [ is actually < and ] is > , etc.
OR
Your tick the box at the bottom of the post where is says [_] Attach a file after posting. Then hit Submit (just hitting Preview doesn't work)
Once you hit submit, you get a screen like this one (which is a capture, not live so don't click on it)
Click on BROWSE and go to the hard drive Folder and the photo you want and select it and click OPEN. Then hit Submit. In a few seconds you will see the photo url show up in the upper right (as shown below). Then BROWSE again for the next photo and repeat the process as needed. Eventually hit RETURN TO THREAD when you are done uploading your photos.
There are some additional options but that should help you get going. That at least, has been my limited experience here.
