Location: Southern CA | My starter stays energized/engaged after start button is released or even after the engine starts. So my first thought is a bad relay, replaced it and the problem persists. Ok, so a new solenoid isn't a bad idea anyway, so I replace it and checked the return spring, problem continues. To troubleshoot, while the engine was cranking (against my wishes) I removed the ignition wire from the relay, no effect, then I put a test light on the solenoid terminal of the relay, it was hot. So it seemed like the relay contacts are sticking closed ($10 relay), so I replaced the relay again, and still have the same problem and test results.
Could the starter bendex be "stuck" in the flywheel, keeping the solenoid contacts closed, sending current back through the solenoid wire, and giving me a false positive reading at the relay solenoid terminal? If yes, maybe I could elongate one of the starter mounting holes to rotate the bendex gear slightly away from the flywheel? 57 392. Thanks
I have same issue...it usually presents itself when my battery is low. I"ve had my starter rebuilt at least 3 times...It kept filling up with water, now i think i fixed that problem, but if the battery is low and i turn it over, after i release the push button it keeps cranking...then it either starts or draws the battrey down lower and lower and I have to scramble to un hook it...I've probably melted 2 or 3 positive cables over the years...I don't have the answer but I feel your pain...thanks for posting, hopefully we'll get some hits on how to fix..
billy
57 Chrysler New Yorker Sedan |
Location: central Illinois | I do not know a thing about the push button Neutral switch but on another car I would suspect the ignition switch. |
Location: Ontario, Canada | Leadfoot1000 - 2017-05-14 11:12 PM
I would suspect the vacuum switch. Just bypass it and see what happens.
Greg |
Location: So. Cal | It sounds like 2 problems. Greg is right, that your vacuum switch should shut down the starter once the motor starts. So you should check and replace that if it isn't doing it's job. But it could be that the engaged starter is preventing the motor from developing very much vacuum to make the switch. Also, the switch on the back side of the push buttons is a little button that gets pushed in to energize the relay. This switch definitely has a tendency to get stuck. So you probably need to replace or repair that as well. It probably requires removing the push button assembly. |
Location: Southern CA | Thanks for the tips guys, but please remember that while the starter was engaged I disconnected the ignition wire from the relay and the starter stayed engaged, removing that wire eliminates both the push button and vacuum switches from the equation as they serve as "interrupters" in the circuit between the relay and battery. I think I will try to find a new solenoid return spring, and get a new starter, I won't mind having a spare anyway, mine has been abused. I'll let you know how it works out. |
Location: Western Colorado | I think you are on the right track. If the solenoid drive return spring is weak or if the bendix/drive is hanging up in the flywheel, it will continue to crank because the solenoid contacts are still engaged. The engagement wire/contact only activates the magnetic windings and pulls the solenoid in/engaged.
If the starter has been hot, ie: battery cable melted, the disengagement spring has most likely been hot and very weak, hence it won't pull the drive back out of the flywheel. On the other hand, if the bendix/drive bushing is dry or the armature shaft "galled", the bendix/drive can hang up and not return properly.
I don't think I would go so far as elongating the starter mount holes. I think a very close inspection of the complete starter assembly would be my first choice.
Good luck.
Bob
Location: Southern CA | So I bought a rebuilt starter from Hot Hemi Heads and it came with a new solenoid. I installed it and the problem persisted. So since all tests that I've done indicate that the relay contacts are staying closed I decided to try a third new relay, but this time I bought an NOS original Standard Ignition brand for $70 off epay. (Remember that I already tried two new Chinese ones that were $10 each. I appears the problem is now solved as I've cranked and started the engine several times now with no issues. The engine also cranks faster now with the starter from Hemi Heads, so that's a bonus. Moral of the story, cheap parts from China are garbage. I didn't imagine two would be defective, but they are. My two garbage relays came from Van's Auto on Epay, beware out there.
Location: So. Cal | Thanks for the warning. Did you take a picture of that starter from Hot Heads? I would like to see what they are like. |
Location: Southern CA | I took one photo while it was still in the box due to minor transit damage of the solenoid, it was not enough to warrant sending it back though.
(FullSizeRender.jpg)
Attachments ---------------- FullSizeRender.jpg (87KB - 176 downloads) FullSizeRender.jpg (89KB - 211 downloads)
