Electrical Cable Connectors Quick Splice; anyone use these?
Posted 2017-04-23 6:45 AM (#538657)
Subject: Electrical Cable Connectors Quick Splice; anyone use these?
50001000500
http://www.ebay.com/itm/100Pcs-Electrical-Cable-Connectors-Quick-Sp...
king-/382054130429?fits=Year%3A1958%7CMake%3APlymouth&hash=item58f43362fd:g:hkEAAOSww3tY5Ieh&vxp=mtr
Type: 2Pin Connector
Color: white, as picture shows
Size: approx. 20*17.5*13.5mm
Quantity: 100pcs
Widely used in the wire connection
Prevents the wire from shorting out
Great for tapping into wires to test
Use with the male quick disconnect for easy safe splicing into wires
Package included:
100pcs x quick splice wire connector .
finsruskw
Posted 2017-04-23 8:38 AM (#538662 - in reply to #538657)
Subject: Re: Electrical Cable Connectors Quick Splice; anyone use these?
2000100100252525
Junk, are not sealed and cut through the insulation and more than likely some of the wire strands in the process.
NOT for use in damp locations for sure.
Water will wick up into the wire strands and rot causing deterioration of the whole wire eventually.
Cheap fix for the lazy man or flipper.
rebel
Posted 2017-04-30 10:47 PM (#539180 - in reply to #538662)
Absolute JUNK. With over 45 years in the mechanical field I have fixed literally hundreds of "wire repairs" where this type of connector was used. Moisture/salt/mag chloride will wick into the wires and can ruin the wire for many, many feet and can even attack the device the wire feeds.
Bob
BigBlockMopar
Posted 2017-05-01 5:43 AM (#539197 - in reply to #538657)
20001000500252525
Never seen those before, but they seem the same as these pieces of feecies;
If severe punishment by hanging from the gonads was possible on shoddy automotive electrical work, the guys who use these should get it. Twice.
Old Ray
Posted 2017-05-01 11:20 AM (#539218 - in reply to #539197)
500
BigBlockMopar - 2017-05-01 3:43 AM If severe punishment by hanging from the gonads was possible on shoddy automotive electrical work, the guys who use these should get it. Twice.
At the risk of expressing what might be considered to be a negative opinion, but just trying to be positively helpful here, and from bad experiences (the great teacher), you are absolutely correct sir.
