Is the Seal on top of the power steering box where the Column shaft joins with Rubber Insulator a Internal or External Oil Seal,
Meaning a quick fix or a tear down.. Also IF a external Oil Seal any links where to purchase the seal ??
Also a Link to get a power steering pump Seal kit also..
Thanks in advance for any help ...
Location: Newark, Texas (Fort Worth) | http://www.ebay.com/itm/1957-58-DODGE-DESOTO-POWER-STEERING-PUMP-KI...
Maybe? |
| make sure you know what pump you have.
That's not for Thompson pumps. I believe the 59 dodge should have the 2nd type of Thompson pump and then there is a federal pump also.
Location: .Norfolk..Mafia.. ,England UK | Only need the New O ring seal kit for the Pump as it has a very minor drip,,
My main leak is top of the steering box though , Was hoping it was also a quick fix on a external Seal,, Just need info or a diagram to show it, Google search doeasnt show anything
| In ordered my seal from online from the o-ring store, they have square ones like factory |
Location: Southern Sweden - Sturkö island | If you mean the adjuster screw/nut, then there's a very normal o-ring under the nut Clive.
If that's your main leak, just loosen and remove the nut without moving the screw and you'll see the remains of the old one
(IMG_1389-rez.jpg)
Attachments ---------------- IMG_1389-rez.jpg (171KB - 164 downloads)
I mean the top of the Steering Box where the column shaft joins, Well that is where it appears to be coming from looking underneath the car,,
(123.jpg)
Attachments ---------------- 123.jpg (176KB - 185 downloads)
Location: Southern Sweden - Sturkö island | Ok Clive, then it's best to rebuild the steering gear, the steering shaft seal is worn out.
(20160511_140007-rez.jpg)
Attachments ---------------- 20160511_140007-rez.jpg (212KB - 193 downloads)
Location: Newark, Texas (Fort Worth) | Sounds like bs but this kit fits 59's?
http://www.ebay.com/itm/Steering-Gear-Box-Seal-Kit-SK405-Chrysler-P...
Edited by mstrug 2017-04-23 8:01 AM
