C68 Newyorker rear u joint
craigt
Posted 2017-04-06 9:10 PM (#537517)
Subject: C68 Newyorker rear u joint
Hi guys, I'm looking for a rear U joint for my 55 Newyorker 2 door hardtop. it doesn't have to be new just a good second hand item.
The u joint must come from a 2 door car as the 4 door u joint is smaller as i found out the hard way...
please help!
new u joints are obsolete...I've been down the path of part numbers and trying to match it to something that's readily available. I've even got our suppliers from my work looking into this.
Thanks Guys.
Shep
Posted 2017-04-07 9:45 AM (#537540 - in reply to #537517)
Subject: Re: C68 Newyorker rear u joint
20001000100100100252525
4 dr and 2 dr are the same if they are both New Yorkers. New are expensive. If you change the yoke on the diff. I believe you can use a standard joint to match.
