Location: Lower Mainland BC | mikes2nd - 2017-03-23 8:55 AM
looks like its just a regular bulb inside. I guess I wouldn't need the housing. Just mount it inside
Don't think so.
"Using a simple three wire system, the insanely bright L.E.D. bulbs inside the machined aluminum housings have two different brightness' to indicate both braking and turning. "
I have a different set-up using 1157s with "insanely bright" LEDs. They are NOT regular bulbs or even regular LED bulbs. Some newer LED technology that creates a retina burning brightness, in red even.
