Posted 2017-03-21 9:51 AM (#536366) Subject: Dodge Dart Phoenix
New User
Hi Guys, New around here. I am working on a 1960 Phoenix - and I am wondering if anyone know how the vent line on the gas tank is hooked up. Since there is no return - I am assuming that a hose must be attached to the terminal on the tank and routed somewhere?
Posted 2017-03-21 2:31 PM (#536380 - in reply to #536379) Subject: RE: Dodge Dart Phoenix
New User
There is definitly a vent line that goes off the back of the tank, that does wrap around the tank to the front area where a baffle is. That vent line has to go somwehere??
Posted 2017-03-21 2:35 PM (#536381 - in reply to #536366) Subject: RE: Dodge Dart Phoenix
Randall375 - 2017-03-21 9:51 AM
If anyone has and idea's that would be great!
Thank you,
Randy
there is a steel vent line going from the filler neck around the tank to the front of the tank where it is connected with a rubber hose to a short piece of @1/4" hook shaped steel line going to a higher, above tank, location in the axle hump/center. its held there with a clip.
