Location: Kennewick Wa | I'm sure others here have dealt with this...
The sealer between the upper and lower portions of the cowl was brittle and broken loose
letting in pine needles and dirt. I have removed the upper part of the cowl due to rust
issues. I repaired the lower part, applied rust inhibitor, given it a good coat of primer.
Now need to know what is used to fill the gap between the upper and lower sections before
I tack on the new upper part... thanks in advance |
