| Hi all, I need the passenger side window track that bolts in the top of the 1/4 panel on a 2 door hard top. It's the piece the two studs of the window glass frame ride in to keep the rear of the glass up. |
Location: Newark, Texas (Fort Worth) | Did you try big M? |
| mstrug - 2017-02-16 7:44 AM
Did you try big M?
Yes, John did not have one. |
Location: Montreal, Canada | dhunter93 - 2017-02-16 9:41 AM
Did you try big M?
Is this what you are looking for? If so, I might have a couple of them.
(image.jpg)
Attachments ---------------- image.jpg (69KB - 87 downloads)
| Thanks ! I need the passenger side one. |
Location: Melbourne, Australia | Ill put my hand up for the other if available please Soiouz ! Colin |
I am out of town untill tonight, I will check to be sure the ones I have are ok, and will let you know. But I am pretty sure I have at least one that is not warped or broken.
Location: Montreal, Canada | I dug into my stuff, and I have only one good pair left. I have another set, but it would need a slight bit of work. |
