Posted 2017-02-05 7:41 PM (#533300) Subject: Doors for 1958 Plymouth
Can anyone tell me the dimensions of the doors from a 2 dr sedan vs a 2 dr coupe. I'm looking at possibly purchasing the sedan doors to replace my severely rusted coupe doors.
Posted 2017-02-06 9:39 AM (#533334 - in reply to #533300) Subject: Re: Doors for 1958 Plymouth
The skins are probably close enough to use but as mentioned the complete door is different. Would it be better to try and find complete doors? I f your skins are rusty what about the rest of the doors?
Posted 2017-02-06 10:29 AM (#533335 - in reply to #533300) Subject: Re: Doors for 1958 Plymouth
I've been looking for complete doors but not much luck. The bottom where the skin folds over is rusty as well but I'm pretty sure I can weld on a new strip and then install the better skins.
Posted 2017-02-06 4:06 PM (#533358 - in reply to #533300) Subject: Re: Doors for 1958 Plymouth
What you are considering is fairly simple. Door width and height is the same, with the exception of where the window frame protrudes upwards. I've done the same thing several times in the past.
