Axle ratio code. 1960 Windsor. 521?
FourFans
Posted 2016-12-27 2:46 PM (#529848)
Subject: Axle ratio code. 1960 Windsor. 521?
Build sheet shows 521 as an axle code. Any idea what ratio this is?
FourFans
Posted 2016-12-27 4:47 PM (#529854 - in reply to #529848)
Subject: RE: Axle ratio code. 1960 Windsor. 521?
Now with photo... hopefully it shows up!
[img]http://i.imgur.com/sCvFFjL.jpg[/img]
Posted 2016-12-27 4:58 PM (#529856 - in reply to #529848)
Subject: Re: Axle ratio code. 1960 Windsor. 521?
50005000200010002525
Yep, that's the standard economic axle ratio 2,93:1
FourFans
Posted 2016-12-27 5:11 PM (#529857 - in reply to #529856)
wizard - 2016-12-27 2:58 PM
Thank you! I am not used to this old of stuff! Galen Govier didn't make any little white books for stuff this old. I really wish there was some reference material on this car. I still haven't found the fender tag.
Rodger
Posted 2016-12-28 10:54 AM (#529905 - in reply to #529848)
1000500
Hola
You may also read this 1959 Chrysler Brochure: http://www.lov2xlr8.no/brochures/chrysler/59ch1/bilder/12.jpg . Notice the ratio is the same in both senior - junior and wagon's too. the tyre sizes could make an effect on the ratio and it is the same from 361 to 413's.
When you look at The De Soto Division you will see a slightly better listing in the 1959 brochure: http://www.lov2xlr8.no/brochures/desoto/59des1/bilder/10.jpg .
Rodger & Gabby
Colo Spgs
59 explorer
Posted 2016-12-28 9:52 PM (#529964 - in reply to #529848)
100100100252525
Data plate should be by driver's side upper door hinge painted the body color
FourFans
Posted 2016-12-28 11:17 PM (#529969 - in reply to #529964)
Thanks!
I will look this weekend!
