'58 Imperial Reostat
Islander 62
Posted 2016-12-21 2:36 AM (#529382)
Subject: '58 Imperial Reostat
Are there any good lubricants for the headlight switch?........I'm dealing with the typical intermittent glow as I rotate the knob, how do you remove the switch and what would you use on the reostat coil?.......
Posted 2016-12-21 11:37 AM (#529415 - in reply to #529382)
Subject: RE: '58 Imperial Reostat
5000200020005001002525
Dielectric grease.
Islander 62
Posted 2016-12-21 12:36 PM (#529423 - in reply to #529415)
Thanks for that information......I'm going to try taking the switch out today.....looks like a bit of a mystery but I'll see what i can do.
KcImperial
Posted 2016-12-21 3:40 PM (#529431 - in reply to #529382)
Subject: Re: '58 Imperial Reostat
2000100100100100252525
Removing the headlight switch is one of the easier tasks on an Imperial dash. There's a Allen head set screw on the knob and then a nut behind that. It pushes through and out the backside. There should be just enough slack in the wires to let it hang down for easier wire removal.
Islander 62
Posted 2016-12-21 11:33 PM (#529468 - in reply to #529382)
Don
Thanks for the info Don!.......I'll be pulling it out tomorrow.....
