NOS carb rebuild?
ABloch
Posted 2016-12-17 11:04 AM (#528962)
Subject: NOS carb rebuild?
1000100100100100252525
Hey there everyone,
I just got an NOS carb off of ebay and I am wondering if I should do anything to it first before I just install it?
I was thinking that considering it's age I might want to pull the accelerator pump out and soak it first but what else?
Thanks, Andrew
plymouth
Posted 2016-12-17 1:03 PM (#528976 - in reply to #528962)
Subject: Re: NOS carb rebuild?
20001001002525
Besides the accelerator pump, I'd also blow out all the passages with compressed air.
ttotired
Posted 2016-12-17 5:14 PM (#528989 - in reply to #528962)
50002000100010010010010025
It will probably need a rebuild, but you could try soaking the whole thing in a container of fuel to soak (and swell) all the dried up gaskets and stuff.
After a week or so, pull it out and empty it, go over the screws and give it a try
Paul Hettick
Posted 2016-12-17 6:28 PM (#528993 - in reply to #528962)
500100100
I poured atf down the vent till the bowl was filled and worked the acellerator pump a few squirts then let it sit for about a week.. Then bolted on the car and it worked perfectly. The atf helps the accelerator pump and gaskets
hemidenis
Posted 2016-12-17 9:55 PM (#529000 - in reply to #528962)
20001000500100100100252525
I used around 4 NOS carbs so far and they need nothing, just bolted fuel and go...
ABloch
Posted 2016-12-19 11:00 AM (#529151 - in reply to #528962)
Well I went with Denis on this. Bolted, fueled and it went off without even a hickup. All I had to do was set the curb idle. Oh, and swap out the air cleaner. Seems the NOS carb has a vacuum pot on it that the other carb did no have and my air cleaner wouldn't fit.
