Location: California | When the pedal is barely touched before it makes contact with the master cylinder getting a rapid chatter through the pedal. Any suggestions? Other than that the brakes work great. |
Location: Minor Hill, TN | The power brake booster might have a leak you might want to have it checked out |
An incorrectly adjusted brake pedal trigger will cause the chatter you describe. Check the FSM for the adjustment procedure. |
