Calling on Imperial experts
plymouth
Posted 2016-11-10 9:07 AM (#525755)
Subject: Calling on Imperial experts
20001001002525
The time has come for me to thoroughly clean and paint/detail the undercarriage of my '63 Crown. I know it's not technically forward look. I'm wanting to paint the suspension and steering components pretty close to factory colors. Does anybody have any reference photos or anything so I can replicate the factory look. Thanks for any help.
61_Imperial
Posted 2016-11-10 3:21 PM (#525787 - in reply to #525755)
Subject: Re: Calling on Imperial experts
100100100100252525
control arms, torsion bars, etc were satin/semi gloss black. the torsion bars had a paint stripe on them. I believe my '61 was a rose pink color. This likely changed year to year.
plymouth
Posted 2016-11-10 4:06 PM (#525792 - in reply to #525787)
20001001002525
Thank you!
C-300
Posted 2016-11-14 11:06 AM (#526207 - in reply to #525755)
100100100100252525
The torsion bar stripe color denoted the thickness of the bar as an assembly line code to make sure the correct set was installed.
Aaron
Rodger
Posted 2016-11-14 12:43 PM (#526214 - in reply to #526207)
1000500
Hola Yo'll
For every year of The Imperial Division - there was only two Torsion Bar "spec's". The cars with out Electric Seats - Windows - A/C - Auto Pilot and the like have "Std".
Start adding this's and that's --- the "HD" torsion bars were used. Of course The "HD" Torsion Bars could always be used for 1001 verified reasons.
Rodger and Gabby
Colo Spgs
60 dart
Posted 2016-11-14 4:15 PM (#526231 - in reply to #525755)
50002000100050010010010010025
you might want to keep in mind never to use course sandpaper or any sort of grinders/sanders on them but scotch brite extra fine will work well
with soap and water or non paint remover solvents------------------------------------------later
plymouth
Posted 2016-11-14 4:47 PM (#526234 - in reply to #526231)
20001001002525
Thanks guys. Do you guys know the correct color of the front away bar and the leaf springs?
