Hardtop window sealing
plymouth
Posted 2016-08-29 4:21 PM (#520117)
Subject: Hardtop window sealing
20001001002525
Hi folks, I am having a time trying to understand the adjustments of the windows on my imperial. The service manual isn't too clear on this. I'm getting water leaks around the vent window frame and along part of the top of the window where it meets the roofrail weatherstripping. The weatherstripping is new. I know you can adjust the vent window and glass but I don't know how. What kind of adjustments can be made? It looks like the window is ****ed causing a poor seal. Here are a couple of pictures. Thanks
(rsz_10829161515a.jpg)
(rsz_10829161515e.jpg)
Attachments rsz_10829161515a.jpg (234KB - 72 downloads)
Attachments rsz_10829161515e.jpg (234KB - 71 downloads)
ttotired
Posted 2016-08-29 6:18 PM (#520125 - in reply to #520117)
Subject: Re: Hardtop window sealing
50002000100010010010010025
You need to downsize your pictures, I cant see what your talking about, but, with my buick hard top, they lined all the rubbers with
a canvas cover, basically, a strip of material glued to the rubber to allow the windows to slide on the rubber and not kink or grab.
I dont know if mopar did the same as my plymouth has no rubbers on it, just a box of random rubber pieces
As for adjustments, all behind the door trims and you have to start at one end and work along all the windows
as you adjust one, it effects the next one
Have fun
1961plymouthfury
Posted 2016-09-03 1:36 PM (#520442 - in reply to #520117)
200050010025
I believe its the rubber between the windows is what he is talking about
Posted 2016-09-03 1:51 PM (#520443 - in reply to #520117)
50005000200010002525
It's more or less the same methods as in this booklet http://www.imperialclub.com/Repair/Lit/Master/150/index.htm
As Mick writes, you need to wrestle around somewhat from vent wing, front and rear windows to get it all in the best position.
