| My neutral safety switch doesn't reset once the engine stops running and prevents another start attempt, It will reset after a minute or so. It varies. I t always eventually resets
but I am stuck waiting for it at times.
Are new switches available? If so a part number would be appreciated.
For those not familiar, it is a switch on the intake manifold that looks for a vacuum signal. Once a vacuum signal is detected the switch goes from a closed position to an open position and prevents the starter from
engaging. I like it and think its a good design, so would prefer not to bypass it. On the contrary it is simple to bypass if needed. |
Location: Under the X in Texas | <p>Bought mine maybe a year ago from Collector's Auto Supply, WA. He had several.</p><p> </p><p>Looking at his web site, that price went UP !</p><p> </p>
Edited by StillOutThere 2016-08-19 3:26 PM
Location: So. Cal | I believe it should be 1770093. There are also several on Ebay, some in the original Mopar style and the later replacement style. |
http://www.ebay.com/itm/NOS-Mopar-1957-1959-Plymouth-Dodge-Chrysler...
Edited by 57chizler 2016-08-19 3:31 PM
Location: DFW, TX | Have you tried removing it and cleaning it? It sounds like it may have carbon buildup that is causing the switch to be slow to reset. |
