Location: San Antonio TX | So I've been thinking about swapping out the rear end in my 61 Windsor for something geared differently to bring down the RPM's a bit at freeway speed. Today my rear end suddenly had some sort of catastrophic failure (burning smell, smoking out the passenger wheel, grinding, pulling to one side, squealing) so I figure now is the time to start looking for one. Any suggestions? Preferably something that hooks right up to the stock drive shaft without modification. If I can't come up with something, I'll probably just do a direct replacement with an identical unit. |
Location: Alaska | Try to find a complete rear out of a 65-67 Chrysler, these will fit with slight modification and may came with 2.94 ratio for easy cruising. The rear out of a big Dodge or Plymouth (880, Fury) 65-67 would be the same. |
Location: So. Cal | Also an E-body Cuda or Challenger is almost the same. May just require an angled shim under the mount to adjust the pinion angle a bit. If you are going to run drum brakes, be sure to get a set of 11" brakes as these cars are quite big and could use the extra braking in the back end. You can get them separately if you don't come across a rear with them already installed. |
Location: San Antonio TX | 58coupe - 2016-06-26 9:55 AM
What exactly is the slight modification that that needs to be made in order to make it fit?
Powerflite - 2016-06-26 10:19
Will I need to modify my brake system in any way to make the bigger drums work? Or will my master cylinder and booster work just fine with the 11" drums?
The '65-'69 C-body (Chrysler, Polara, Fury) rear ends are a virtual drop-in. There is a 1/2" difference in the spring pad width so a purist might want to move the spring perch pads but, in reality, they will work as is. The later rear end is 5/8" wider overall but that rarely causes any problem.
Since 11" rear brakes were used on the FL cars there aren't any changes needed to the hydraulic system. |
