| I have installed a 6 Way power seat setup in my 59 Plymouth with Swivel Seats with only one issue.
I can not figure out where to rout the wring harness from the Motor to the Switch without interference and pinching from the seat adjuster when in the down position or the Swivel operation? See photos below
Can anybody advise how this was done and send a few photos of the harness routing and Switch mounting location
Thanks . Mark
(switch2.JPG)
(switch.JPG)
(switch3.JPG)
Attachments ---------------- switch2.JPG (34KB - 136 downloads) switch.JPG (35KB - 142 downloads) switch3.JPG (31KB - 135 downloads)
Location: Newark, Texas (Fort Worth) | Looks like the wiring would go under the silver bracket and zip tie it out of the way. marc. |
| No clearance when the seat is all the way down ,will cut the wires
I am looking for a Photo or Diagram all an orig install |
Location: Hay Lakes, Alberta, Canada | The drawing in the '59 parts catalog, shows the wiring harness clipped to the top of the rack, in the center, between the two seat bolts. It passes between the rack and the seat frame. |
| Thanks.
When you say "Top of the Rack " Do you mean the Black Top Horz Bar of the Power section ?
Can you please send or Post the page # or send a copy of the drawing. I assume you mean the Big 59 Parts Book
I only have a 1/4" of clearance b/t the 2 items you mention, only 3" running front to back
Thanks , Mark |
Location: Hay Lakes, Alberta, Canada | Yes, the top of the bar. I've attached the pic from the parts book. I hope it helps...
(IMG_0199.JPG)
Attachments ---------------- IMG_0199.JPG (44KB - 124 downloads)
