Posted 2016-03-13 9:48 PM (#506723 - in reply to #506410) Subject: Re: 1956 Chrysler Temperature Sending Unit
I found a very affordable replacement, Standard part number TS527 is $11.30 @ rockauto. I have a 165 degree F thermostat in the Imperial (factory recommended temp, believe it or not) and when the car is up to that temperature the gauge now reads slightly below half way between C and H. It has 1/4 NPT threads which in my case does not require an adapter bushing.
