Torqueflite Transmission adjustment
MeSa
Posted 2016-03-08 1:38 PM (#506173)
Subject: Torqueflite Transmission adjustment
Hi @all,
how can i adjust the push button outside of the transmission?
THX for all informations
Shep
Posted 2016-03-08 1:54 PM (#506176 - in reply to #506173)
Subject: Re: Torqueflite Transmission adjustment
20001000100100100100
What car?
MeSa
Posted 2016-03-08 1:56 PM (#506177 - in reply to #506176)
57 DeSoto Firedome
Posted 2016-03-08 2:02 PM (#506178 - in reply to #506173)
50005000200010002525
The best way is to pull the pan and check that the ball goes into each detent full and good......
Shep
Posted 2016-03-08 2:10 PM (#506179 - in reply to #506178)
wizard - 2016-03-08 2:02 PM
Agreed, but maybe she also wants the method.
MeSa
Posted 2016-03-08 2:10 PM (#506180 - in reply to #506177)
Right now when i push R all is OK, N the car drives also backward, D is neutral, 1 and 2 ok
Posted 2016-03-08 2:41 PM (#506188 - in reply to #506173)
Here's a good little manual - just dowload the pages http://www.imperialclub.com/Repair/Lit/Master/113/index.htm
roope68
Posted 2016-07-31 9:45 AM (#518053 - in reply to #506180)
MeSa - 2016-03-08 9:10 PM
Right now when i push R all is OK, N the car drives also backward, D is neutral, 1 and 2 ok[/QUOTE
Thats my problem too!!
60 dart
Posted 2016-08-01 12:11 AM (#518100 - in reply to #506173)
50002000100050010010010010025
cable adjustment at the cable end/wheel
(1) engage in reverse-drain about 3 qts. of fluid
(2) remove cable wheel lock bolt
(3) remove neutral switch-cup and seal
(4) have a friend hold button in reverse until process is complete
(5) back off cable adjustment until 2 or 3 threads are showing
(6) push cable back into housing just enough to seat o ring and turn adjustment wheel just enough to make contact with trans. case
(7) let pressure off the adjustment end of cable-turn clockwise to next hole then turn 4 more holes-replace neutral switch and TOP OFF WITH FLUID TO FULL
Posted 2016-08-01 1:46 PM (#518131 - in reply to #518100)
20001000500100100252525
'57 doesn't have the adjustment wheel, it has the slotted slide adjustment shown in the link above.
