| I swapped out the 59 belvedere spindles for 77 Aspen spindles now my wheels sit cambered. Is there anyway I can adjust this on my own. |
Put the 59 spindles back on
I do not recall anyone saying any later spindles fit these cars
One of the reasons they make adapters to fit disc brakes and not say bolt this or that on
Location: WHEELING,WV.>>>HOME OF WWVA | i got aspen spindles my my dart . to get the correct camber , it'll need to be aligned by prof. . they should fit 57 - 61 dodge , ply , desoto . if you try to adjust them on your
you'll just be fighting a losing war by fighting camber against toe in or out . mine i think are 78-------------------------------------------------later |
Location: Perth Australia | Now I can say I recall someone saying 78 aspen ones work
Did you just change the spindles or did you have to change anything else (wishbones ect)?
Location: WHEELING,WV.>>>HOME OF WWVA | from the spindles out and cut the tie rod ends @ 1/4 inch . at the time a guy on epay was selling the used parts as a kit , which was cheap @ 175$ or so and came with a list of all the accessories
needed along with the part numbers , model and year . oh , the rotors and calipers were new -----------------------------------------------later |
