| What is the best transmission fluid to use in a '55 DeSoto powerflite trans? Dex-Merc? |
Dex-Merc will work fine. Type A, which was the original spec, is still available.
http://www.amazon.com/Coastal-Type-ATF-qt-case/dp/B00H56D310/ref=sr... |
| thanks for the info.....much appreciated. |
Location: Tampa, Florida | Type A trans fluid is also available at off brand stores/gas stations. Coastal is one of the brands. Next time you are at a mom and pop store/gas station, wander back to the automotive supplies and you may find typa A. |
