Constant Control : Neutral position
Chrome58
Posted 2015-09-07 3:46 AM (#489091)
Subject: Constant Control : Neutral position
1000100100100
Hello everyone,
I bought a refurbished Constant Control power steering box (probably a later model : '61 or '62, as it had a '2-and-something' part number)
When I installed it on my car, I centered it approximately, using the "lock-to-lock and take the middle position" method.
I still have to restore the pump, so the system is not under pressure at the moment.
I know from the FSM that I can later adjust the "neutral position" of the steering box using the position of the upper valve body.
My question is : How much can it take ? Can I be really off center and still be able to adjust the steering to a neutral position ?
Thanks.
Posted 2015-09-07 3:55 AM (#489092 - in reply to #489091)
Subject: Re: Constant Control : Neutral position
50005000200010002525
Nope Vincent, the control valve is only for start of power assist, not for centering the steering linkage. The centering of the linkage is done by the adjusting sleeves on the inner tie rod ends.
Chrome58
Posted 2015-09-07 5:11 AM (#489095 - in reply to #489092)
1000100100100
I think you misunderstood me, Sven : I was not talking about the centering of the linkage.
I was talking about the neutral position of the pivot lever inside the upper valve body.
When your wheels are straight, that pivot lever is supposed to be at the neutral position inside the upper valve body.
That position ensures that no pressure is applied to the left or to the right.
As I centered the steering linkage approximately, I am unsure about the pivot lever position.
(DH.png)
(Constant Control.png)
Attachments DH.png (64KB - 122 downloads)
Attachments Constant Control.png (105KB - 121 downloads)
Posted 2015-09-07 5:30 AM (#489096 - in reply to #489091)
No misunderstanding Vincent, once you get the pump connected and filled up - then you'll start the engine and see if the steering gear "self-steer" in one direction - if not, then all is good. If it self steers to one direction, then the valve bodymust be carefully moved the other direction.
Chrome58
Posted 2015-09-07 5:38 AM (#489097 - in reply to #489091)
1000100100100
OK, thanks Sven.
Posted 2015-09-07 12:56 PM (#489125 - in reply to #489097)
20001000500100100252525
The weight should be off the front wheels when checking for self-steer.
Chrome58
Posted 2015-09-07 1:46 PM (#489127 - in reply to #489125)
1000100100100
Thanks for the tip, John.
