Location: SD | OK, another flathead 6 question: what's the best way to remove the damper? There are no holes to thread in a puller. Soaking with penetrating oil and some gentle persuasion has done nothing. Thanks! |
Location: Blythewood, SC | I've torn four of these down and every one has had holes that are not threaded. Put a bolt through with a nut on the back. |
Location: SD | After I read your reply, I went out and scraped the grime off, and voila! Two holes! They were so filled with dirt/grime that they didn't show up at first! Thanks again for coming to my rescue, Brian. |
