Posted 2015-06-15 3:21 PM (#481595 - in reply to #481560) Subject: Re: torque specs grade 2 titanium bolts
Look it up in the Machinery Handbook. Titanium is so brittle I can't imagine what you would want to use it for. Use trial and error, put one in a vice and see on a torque wrench where it brakes , then go only half of that and you will have the right amount of torque.
Posted 2015-06-15 4:07 PM (#481598 - in reply to #481595) Subject: Re: torque specs grade 2 titanium bolts
Grade 2 is pure titanium (not alloyed)....inferior in strength to the cheapest steel bolt. Alloyed titanium bolts are superior in strength to most steel....widely used in the aircraft industry.
Posted 2015-06-15 6:10 PM (#481609 - in reply to #481595) Subject: Re: torque specs grade 2 titanium bolts
ruchaven - 2015-06-15 3:21 PM
Catch ya later.
yup its not much stronger than 7075 aluminum. i'm using lots of aluminum bolts or nuts in my car, where strength/safety is of no concern. found lots of cheap 3/8" ti bolts and thought i could replace the intake/exhaust bolts but 30 ft/lb wont do.
if titanium behaves like steel its hard to tell when it breaks. usually only the threads shear which is hard to tell when exactly.
