User has resigned from board
| studebaker 15" wheels from the early 60's will fit, they will except the large 10" dog dish hubcaps, bolt patterns the same , i inquired in a studebaker club, parts wanted section, those studebaker men are Aokay in my book, guy up in eastern canada sold me 2 perfect perfect 15" wheels for 10 bucks each and 54 to ship, WOW! thats whats lacking in this hobby, everyone is trying to rip off everyone, next time you see an old studebaker haulin ass, give him a thumbs up!!
Edited by 196061SAVOY 2015-03-06 7:15 PM
(1965demmerwithstripe.jpg)
(1961_Ramchargers_2.jpg)
(65_442_WilFisherOlds1-600x481.jpg)
(1959672_1459223400961491_1763250662_n.jpg)
(Accident.jpg)
(0723570000Loring04.jpg)
(edmond4_zps05d34303.jpg)
(Gasser.jpg)
(sonoramic61plymouth.jpg)
(NY.jpg)
(TXTexasHwyPatrol1961Plymouth-vi.jpg)
(60p.jpg)
(4edef03a3a3351212a94a44a5962c466.jpg)
(elmirage252.jpg)
(Jan01-vi.jpg)
(P1010029-1.jpg)
(wJerseyStatePolice1960Plymouth-vi.jpg)
Attachments ---------------- 1965demmerwithstripe.jpg (123KB - 246 downloads) 1961_Ramchargers_2.jpg (28KB - 253 downloads) 65_442_WilFisherOlds1-600x481.jpg (47KB - 245 downloads) 1959672_1459223400961491_1763250662_n.jpg (88KB - 236 downloads) Accident.jpg (44KB - 253 downloads) 0723570000Loring04.jpg (42KB - 250 downloads) edmond4_zps05d34303.jpg (51KB - 275 downloads) Gasser.jpg (20KB - 247 downloads) sonoramic61plymouth.jpg (27KB - 253 downloads) NY.jpg (109KB - 308 downloads) TXTexasHwyPatrol1961Plymouth-vi.jpg (25KB - 243 downloads) 60p.jpg (24KB - 254 downloads) 4edef03a3a3351212a94a44a5962c466.jpg (32KB - 255 downloads) elmirage252.jpg (20KB - 255 downloads) Jan01-vi.jpg (35KB - 263 downloads) P1010029-1.jpg (29KB - 250 downloads) wJerseyStatePolice1960Plymouth-vi.jpg (24KB - 247 downloads)
Location: Newark, Texas (Fort Worth) | good Idea! Do some of them have slots or cooling holes? I plan on disc brakes and will want 15" wheels I know later Mopar wheels have some sort of slot to allow air to pass thru. I will be using wheel covers that are ventilated and match 1958 Belvedere caps. marc.
Edited by mstrug 2015-03-06 8:47 PM
| <p>that's correct, bob mosher , out in sunny cal, runs the Studebaker 15", on his early 60's max wedge mopars ,and they all run disc up front , look the same as orig { moparmax super stock broker mosher muscle car motors shop tour} google this theres a story on mosher and his stuff</p>
Edited by 196061SAVOY 2015-03-07 6:34 AM
(MOSHERS-14.jpg)
(MOSHERS-19.jpg)
Attachments ---------------- MOSHERS-14.jpg (28KB - 253 downloads) MOSHERS-19.jpg (18KB - 255 downloads)
The Stude 15" wheels that I've had were only 4" wide, great for the skinny front tires favored by drag racers but not very practical for larger tires. |
| <p>SIR , who cares, ride it like u stole it!! iv had no problems at all running them on my 60/61 savoy, 65 442 4 speed, that will smoke those tires up, bob runs them on his max wedge cars now and back in the real world , all pure stock drag racing( if u know what that is) are required to race with bias ply, iv found no issues what so ever, but then again I run lucas general bias ply black walls, maybe its those gay cheap radial coker white walls that may give some a problem , if your (generaly speaking) not running bias ply, why run at all</p>
Edited by 196061SAVOY 2015-03-07 6:59 PM
Location: So. Cal | I sold all 5 of my '56 Plymouth 15" wheels to a max wedge guy that takes them to a rim shop and welds wider hoops to the original centers. Pretty good idea. If I had known of a good shop to do that, I would have kept them to do the same thing. |
Location: Under the X in Texas | I've had new wider "hoops" put on to original centers by Stockton Wheel in CA. |
Location: STL, MO | Kurt McKim does mine. Shop is in Iowa, McWheels. Now the "Wheelguy" is selling the centers that take the large 66 and earlier dogdish. |
Location: So. Cal | Are the centers sold by the Wheel Guy new pressings or old centers he has scavenged? |
Location: Ponder, TX | Many half-ton seventies Dodges had 15" wheels, and there should be a glut of them, though I'm not sure if the truck poverty caps are the same size as the car. I'm quite sure the lug spacing is the same as the cars.
Edited by GaryS 2018-12-26 10:34 AM
Location: Kalispell, MT USA | These are what I got from the salvage yard near me. Off of a late 70's B-100 van. Uses the small center cap. I have not tried the older poverty caps on them. 15x6.5 i believe, 5x4.5 bolt pattern.
(20180422_183556.jpg)
Attachments ---------------- 20180422_183556.jpg (137KB - 189 downloads)
Location: STL, MO | The 66 and earlier wheels use the bigger hubcap. The problem with those wheels besides being somewhat hard to find is they have trouble clearing disc brakes. Until I did some grinding they rubbed on my AAJ combo on my 58 Plymouth, they rode the caliper on my 65 Coronet using the "Disco-Tech" method from Mopar Action using A body spindles on the early B body. Both times was with 15's. Hopefully the Wheelmans centers wont have that issue. The MaxWedge guys are the reason for this repop |
Location: ZH, Switzerland | By the way, what's the stock back spacing of the original 1960 Chrysler 14" rims/wheels? I assume to change to 15" rims/wheels the back spacing should be more or less the same. It's because Im opting to 15" rims/wheels as well for my Letter.... Happy Restoring! Dieter |
Location: So. Cal | Backspacing always depends on wheel width, offset doesn't. The stock offset is 1/4". The '60 Chrysler wheels are 6" wide so they would have a backspacing of 3.75". But I have found on my '58 Coronet that if you go to a wide 8" wheel in the rear, you need to put the offset to zero to make it fit well. |
Location: northern germany | Powerflite - 2019-02-17 10:56 AM
All the 60/61 wheels (Plymouth/Desoto 14") I ever measured had all a 1/2 offset. |
Location: Alaska | I owned a 72 Dodge D100 that had 16" wheels that were 5x41/2" These looked like a factory stock wheel but must have been an option. |
Location: ZH, Switzerland | Thanks a lot for your answer related to the offset/back spacing. I plan to run 6" wide rims, but 15" diameter. Could be that I'm going to aim to 15" rims that will accept 14" hub caps. Happy Restoring! Dieter |
Location: northern germany | 1960fury - 2019-02-17 12:08 PM
All the 60/61 wheels (Plymouth/Desoto 14" ) I ever measured had all a 1/2 offset.
As I'm about to order a set of custom made rims, I just measured all the OE wheels I have and yes, I measured it right 20+ years ago. All wheels are +1/2" offset.
Offset is important. You can't just add any rim that fits. It affects handling and the wrong (mostly positive) offset affects the scrub radius and therefore handling and bump-steer.
Edited by 1960fury 2019-03-14 8:22 PM
(scrub radius.jpg)
Attachments ---------------- scrub radius.jpg (41KB - 173 downloads)
Location: So. Cal | But...if you go with a taller wheel, you want a little less offset so that the scrub radius remains in the same spot. The opposite for smaller wheels. |
Location: northern germany | Powerflite - 2019-03-14 10:25 PM
I personally hate the hot wheels look or giant rims and tire diameter should remain about the same. I also like the lowered look and with taller wheels this harder to accomplish as even with stock wheels, in the front you run out of adjustment very soon.
Edited by 1960fury 2019-03-15 9:48 AM
Location: Southern Sweden - Sturkö island | Makes me wonder if we talk about the same thing? I get 0,395" (10mm) when I measure
1960 Chrysler Original Rims
Rim 14X6 bolt circle 5x4,50” (114,3mm) Offset ET+10 (180mm external width (152,4mm/6” internal width) divided by 2 = 90. Rim edge to abutment = 100 mm. 100 minus 90 = 10 mm positiv.
Measuring the ET
Measure the rim width (C)
Measure from the backside rim edge to the abutment (mounting surface against the hub) (B)
Subtract B with half of the rim width, the result is the compression depth (A), formula ET = B-(C/2)
(ET.jpg)
(RIM.jpg)
Attachments ---------------- ET.jpg (10KB - 175 downloads) RIM.jpg (18KB - 183 downloads)
Location: Southern Sweden - Sturkö island | As for tire size, this is what I have and they are next to the same diameter as the bias ply
Radial Type 235/70/15”
DW = 381mm : [Diameter of the Wheel (DW)15": DW = 15 x 25.4mm= 381mm]
HT = 164.5mm : [Height of the Tire (HT): HT = 235mm x 70% = 164.5mm]
OD = 710mm : [Overall Diameter (OD): OD = DW + (2 x HT) = 381mm + 329mm = 710mm (or 27.9")]
Overall Diameter measured OD = 708mm – I wonder how accurate (02).
CC = 2229.4mm : [Circumference (CC): CC = OD x 3.14 (pi) = 710mm x 3.14 = 2229.4 mm (or 87.7")]
Location: northern germany | wizard - 2019-03-15 10:54 AM
Measuring the ET
I do not measure the lip, as shown in your picture, as they are different inside/outside on some rims. I measure under the lip, so I know the exact centerline. It is possible that the 6" wide rims are different from the 5" and 5.1/2" I measured. But 10mm is only 2.7mm away from 1/2". The distance from the centerline of the wheel to the mounting surface is 1/2" positive for the 5" and 5.1/2" wheels.
Edited by 1960fury 2019-03-15 7:25 PM
