| I'm trying to source some original carpet (with the gold lurex thread) but have concluded there is none available anywhere. I am now working on having some remade and either here in the UK where I live, or in the US. I have some leads on places which will do a color match and will be trying to hand weave in the gold thread. I have been lent an original sample taken from under the seats where it should not have faded or been damaged. The color is a very unusual one which is going to be difficult to match, to my eyes is it s "grey/brown" which might be why it was originally called "charcoal according to Wayne Graefen's book on this model.
Picture attached (original sample on the right - sample of ACC Trinadad Black with silver lurex is on the right) I don't think the Trinadad is anywhere near close enough to use. does anyone have any other pictures of original carpet for us to look at and compare?
Many thanks
Mark http://www.forwardlook.net/forums/images/emoticons/smile.gif
(carpet2.jpg)
Attachments ---------------- carpet2.jpg (160KB - 233 downloads)
Location: Hay Lakes, Alberta, Canada | What is the "Lurex" made of today? Is it possible to "fade" the black carpet somehow, without harming the colour of the gold? If so, you'd have a closer match... |
the sample you have looks to be pretty close to the right color, my sample is more faded than that, but going by the original color of dash pad it looks similar to the Brown charcoal color,
Paul.
(adv carpet.JPG)
(adv carpet2.JPG)
(dash pad3.JPG)
Attachments ---------------- adv carpet.JPG (70KB - 248 downloads) adv carpet2.JPG (95KB - 275 downloads) dash pad3.JPG (157KB - 245 downloads)
Location: Blackpool, United Kingdom. | miquelonbrad - 2015-01-06 3:54 AM
Brad the lurex is still available to buy, its like a synthetic material,similar to mylar so i don`t think it would dye or fade
(lurex thread Gold.JPG)
Attachments ---------------- lurex thread Gold.JPG (80KB - 280 downloads)
If you want a original sample email me you adress |
| Hi there, that would be great if you could mail me some original. The address is
Mark Roe
Fieldings
Ashfield Road
Framsden
Suffolk
IP14 6LS
Do you have an Adventurer if so what carpet has your got in it? did you manage to get some of the reproduction carpet before the supplied dried up or are you looking to get some if I can get it made?
Assuming you have and Adventurer, have you got any photos you could e mail me? My e mail address is mark_roe@Tiscali.co.uk
Where in Sweden are you? I visit Norway quite often on business and sometimes go to Sweden.
Best wishes
Mark |
| Hi Brad, the problem with the black "Trinadad" carpet is not just the color. The pile is not right, and the lurex is much too wide, more like a band of metal, also there's quite a bit too much of the metal in it, so even if we could fade it, assuming it faded to brown rather than grey, I think it would still look wrong.
Cheers
Mark |
| Hi big chrysler
Looking back at your post in June, I did try to reply with my address and some other thoughts but maybe you didn't get it? Here is my message again in case I messed up! I would really appreciate an original sample of the carpet if you have some and any ideas where you got your carpet from? Also I'm thinking of coming to Sweden with the car next year if its re-commissioning goes well. What time of year would you recommend and what shows/meets are there? Best wishes Mark
Mark Roe
Fieldings
Ashfield Road
Framsden
Suffolk
IP14 6LS
Best wishes
Mark |
nearest i can get to that color is Charcoal grey?
Paul.
(CC-5505_L-01.jpg)
Attachments ---------------- CC-5505_L-01.jpg (27KB - 252 downloads)
| Hi Paul
I think you're right, that is about the closest match I've seen. It was definitely called "Charcoal" and Wayne's book on the Adventurer confirms this and suggests it was charcoal fading to very dark brown (like Hershy's Dark he once told me).
I think this will come down to two options:
1. Have some hand made as (hopefully) an exact to Ed Petrus' original sample from under the seats (should not have faded), complete with factory woven lurex thread = expensive
2. Get some off the shelf Charcoal and some lurex and needle and spend a few weeks weaving it in - time consuming but much less expensive!
Where did you get that sample from please?
Best wishes
Mark |
Location: Layton, Utah | Has anyone seen how close the carpet colors are at " Factory OEM Parts " ? There are 4 or 5 possibilities. |
Location: New Castle PA | I believe the Factory OEM Parts sells the Auto Custom Carpet line. Same carpet, but a lot less expensive. ACC didn't have a good match to the original color. |
