Location: Ontario, Canada | It has been more than 20 years since I did any of this work and products have improved as my memory has gone down hill!
Head gaskets for this era of engines: install them dry or with a sealer and if so, what sealer?
I'll have more questions as time goes on.
Greg |
Location: Williams California | Modern head gaskets use no sealer. The old steel and copper gaskets required it, but nothing made in the last 20 years does.
---John |
Location: Ontario, Canada | Thanks, John, I'll check to see how "old" the gaskets look in my kit.
Greg |
Location: Ontario, Canada | Looks like I might be under the wire?
Greg
(image.jpg)
(image.jpg)
Attachments ---------------- image.jpg (112KB - 100 downloads) image.jpg (121KB - 103 downloads)
Location: Ontario, Canada | As I recall, I used this stuff on most other paper and cork gaskets. Is there a better product today?
Greg
(image.jpg)
Attachments ---------------- image.jpg (131KB - 101 downloads)
The gasket you show looks metallic, but is a composite material with steel core. No need for gasket sealer, just be sure the surfaces are clean. The steel and copper gaskets I was referring to were wafer thin, and required gasket shellac for them to seal properly.
---John |
Location: Ontario, Canada | Thanks, John, I appreciate the help.
Greg |
It's a graymarine engine.
A wedge/big block? |
Location: Ontario, Canada | They were AMC engines. As far as I know they were offered in three displacements. 250, 289 and 327 CID's.
I should switch this thread over to; Latest resto project. In the Nether Region
Greg |
