61 318 oil filter
fenix
Posted 2014-09-29 11:37 PM (#457752)
Subject: 61 318 oil filter
2000100
Don't really wanna run the canister, I know ya need the Hot Heads bypass thingy, but what then?
60 dart
Posted 2014-09-29 11:43 PM (#457753 - in reply to #457752)
Subject: Re: 61 318 oil filter
50002000100050010010010010025
you don't need no thingy . just get an adapter , straight or offset , put a filter on it . with those shorty headers , get an offset one --------------------------------------later
fenix
Posted 2014-09-29 11:51 PM (#457755 - in reply to #457752)
2000100
Really? thanks Chuck, I have an adapter already, I'll post a pic asap, when the motor comes back I'll check it out. No filter bypass thingy needed?
60 dart
Posted 2014-09-29 11:59 PM (#457760 - in reply to #457752)
no
Mopar1
Posted 2014-10-03 1:42 PM (#458132 - in reply to #457752)
2000100025
From what it says in the Tex Smith Hemi Book you can take the spin on assembly off an LA engine & put it on the A Poly. On the hemi the "By pass plug" replaces the anti-drain back check ball, I assume that the Poly has a similar check ball.
fenix
Posted 2014-10-03 2:09 PM (#458134 - in reply to #457752)
2000100
Yes, but mine is a 61 Poly with the old cartridge filter, does this info still apply?
oldwood
Posted 2014-10-03 4:16 PM (#458142 - in reply to #458134)
2000500100100100100
There is a spin-on adapter that can be used on a poly. I do not have that info but I know there is one made for the poly. Let me know when you get one because I need it for my '59 Belve.
fenix
Posted 2014-10-03 4:22 PM (#458144 - in reply to #457752)
2000100
Someone syas Fram kakes a kit to convert or the dealer has the parts, I just need to know if it's for a 61 poly and earlier. when did the spin on become available on the poly?
rockerarm
Posted 2014-10-03 4:30 PM (#458145 - in reply to #457755)
5001001001002525
fenix - 2014-09-29 11:51 PM Really? No filter bypass thingy needed?
A plate and center nut adapter from any LA engine will work on your poly. Or you can use the later 90% adapter if you are having header clearance issues.  both will accept a fram PH43 or PH8A spim on filter. First thing I do on any poly 318's I own.
fenix
Posted 2014-10-03 5:25 PM (#458152 - in reply to #457752)
2000100
Okay, Thanks Will, thanks all!
60 dart
Posted 2014-10-03 6:03 PM (#458160 - in reply to #457752)
the only things you need are a 90 degree or straight adapter and filter of your choice and a gasket .-------------------------------------------------later
