| My Dad has had this '58 Dodge ragtop sittin in his shop for the last 20 years. He bought it as a stripped down rolling tub. The title we have for it says its a Custom Royal Lancer. Could You guys decode this for me? Any help would be greatly appreciated. John
(58 Vin Number.jpg)
Attachments ---------------- 58 Vin Number.jpg (133KB - 227 downloads)
Your all-white Custom Royal convertible, with the Ivory/Black interior scheme, and a white-top, was built in Detroit,
on or around October 10, 1957.
In no particular order, it has the Convenience Accessory group (foam rear seat; variable speed wipers; Jiffy Jet; and handbrake/
map/glove box & trunk lights; and vanity mirror)
Also: Safety Group (Power Steering; Power brakes' padded dash' padded sun visors).
Radio Group: heater/back-up lights; LT IO/S mirror; Day/Nite mirror; push-button radio.
It was delivered by Truck to the dealership.
It has tinted glass and the shaded windshield.
And: Deluxe Appearance Group: 2-tone steering wheel; Spinners!; stone shields; clock
Torqueflite transmission.
Undercoating.
It also has (many-) other options which will be confirmed on its IBM Build card and/or on its Broadcast Sheet.
Have you looked up/behind its glove box to see if its Broadcast Sheet might still be masking taped there?
NICELY optioned car!
Edited by d500neil 2014-09-29 11:57 PM
| Thanks Neil! I really appreciate it. Haven't looked for the broadcast sheet but don't hold much hope of finding it. The top was non existent as it sat outside for many years before dad got a hold of it. |
Location: Sept. 1958 | That's a hell of a car. Any pics???? |
| Sorry to say but its buried back in the corner now & I can't get any. I think we have some old snapshots from shortly after we acquired it. I'll see if I can dig 'em up. |
Location: The Mile High City | So, when your dad stripped it down to a rolling tub, did he save any of the pieces / parts, or is it pretty much just a shell? |
| He didn't strip it, he acquired it that way. We've got a four door sedan for parts. Too bad the trim won't work. We moved another car outta the shop the other day so I got some pics. I'll try to get 'em posted here later. |
Location: The Mile High City | Aha! I need to actually read the posts! I would love to see pictures of it! |
| Well, here she is. Brutalized but still beautiful!
(20141005_142037.jpg)
(20141005_142242.jpg)
(20141005_142120.jpg)
(20141005_142127.jpg)
(20141005_142143.jpg)
Attachments ---------------- 20141005_142037.jpg (76KB - 210 downloads) 20141005_142242.jpg (207KB - 229 downloads) 20141005_142120.jpg (166KB - 204 downloads) 20141005_142127.jpg (165KB - 211 downloads) 20141005_142143.jpg (178KB - 208 downloads)
| Parts car.
(20141005_142652.jpg)
Attachments ---------------- 20141005_142652.jpg (233KB - 209 downloads)
I would love to get my hands on a convertible project like that! It would be a stunning car if restored to original all-white color! |
Location: Ontario, Canada | John, it looks like a fun project to do. I'm sure both you and your Dad are asking the same question;"Why the hell would anyone torch cut the frame like what was done??!!" I would suggest to get that 4dr car jacked up and out of the dirt because you are going to need its frame!
Greg |
Location: The Mile High City | Good stuff, John! Like Greg said, there were some WEIRD things done to that car, but it looks pretty solid still! That will be a great car and it appears that the top bows and some of the hard-to-find convertible stuff is still there. |
Location: bishop, ca | John, among the many parts that you will be needing, on/for your car's restoration will be a complete 57 Dodge sway bar system, including its welded-on mounting
brackets and 'hangers'.
The 1958 Dodges did not have a sway bar system on them.
The location/installation of the sway bar brackets is easy to confirm, via the pre-existing slots that are already cut into the frames, for the
the sway bars' (possible-) installation on them.
Finding/buying a 1957 Dodge sway bar system should be relatively easy and cheap, because not many people are retrofitting 1957 Dodge sway bar
systems onto their cars.
Edited by d500neil 2014-11-14 1:10 AM
Location: bishop, ca | One benefit of installing a 1958 (donor) frame onto a 1957 restoration is that all of the 1958 frames have beefier torsion bars
on them than do the 1957 Custom Royal models.
The 1957 Custom Royals have a standard-equipment (expensive) sway bar on them, which allows them to have/use softer T/bars,
for a comfy ride, without sacrificing handling response.
So, installing the standard 1958 Dodge T/bars (which were optionally available on the 1957 Dodges) along with a 1957 Dodge Custom Royal's
sway bar will increase the handling of that car.
Again, your '58 will already have the beefier bars in it, and, a 57 Custom Royal model should have a sway bar on it.
Edited by d500neil 2014-11-14 1:38 AM
Location: Ontario, Canada | Hey, Neil, are you actually making HUMAN mistakes?! There is nothing 57 about any of this restoration!! There are usually NO slots in a 58 frame to precisely index earlier sway bar brackets!! Even if there were, one cannot adapt a sway bar onto 58 struts. 58 struts are round whereas 57 struts have a flattened area at their ends to accommodate the sway bar bracket end clamps. What else do you need to know to complete this picture??!
Greg |
Location: bishop, ca | I thought that John's 58 body was going to be the basis for a 1957 chassis restoration...in which case the rear springs and their
perches/hangers, too would require retro-fitting between those two years.
Location: Ontario, Canada | Yes. For two years where the cars looked so similar there were many subtle differences when one goes to marry things together.
Greg |
Location: Parts Unknown | alice520 - 2014-12-03 10:00 PM
Make sure edges and corners are smooth and rounded for Stone Island TrackSuits sale safety. The most widely used counter top materials for many years were Formica and laminates. Now lower Cheap Men’s Stone Island Shorts costs and technology are replacing laminates with natural stone and newer fabricated surfaces. Some counter top materials include butcher block, ceramic, concrete, copper, granite, laminate, limestone, marble, quartz, slate, soapstone, stainless steel, stone, tile, and wood.
This is a good example of why I love this site. More information than you ask for and the kind
of detail you can't get anyplace else !
| Wow, I guess!! Which code shows my counter top option?!! |
Let's not overlook what code shows the original track suit you'll need to be looking for !
The 58 Plymouth track suits are available through Legendary Auto Track Suits, but for Dodge
and DeSoto, you're on your own to find an original. |
