| Trying to figure out if my '59 Coronet with a 326 cu in engine has the 2 sd Powerflite or the 3 spd Torqueflite. Any body know how to determine this?
As well, will a 2 sp Powerflite bolt up to a 383 cu in engine?
Location: Chestertown, NY ( near Lake George) | How many buttons on the shifter, if dr and low, it is a pf.
Location: Ripon, WI | Not 100% true... Only if it is stock. Remember you can use the 2 speed pushbuttons with a 3 speed trans. |
Location: Chestertown, NY ( near Lake George) | Gotta start somehwere, based on the tone of the question I assumed it was stock. |
| Yes, it is stock. Thanks for your reply, question answered. |
