Ram Induction operation
horace
Posted 2014-09-19 3:12 PM (#456797)
Subject: Ram Induction operation
I have a 60 D500 Ram, the thing idles like really fast, am I missing a spring or??? to idle this thing down. I forget the name of the thing between the carbs isn't it supposed to go in & out to keep idle from falling to low?? Thanks
Posted 2014-09-19 3:24 PM (#456798 - in reply to #456797)
Subject: Re: Ram Induction operation
50005000200010002525
The idle should be higher on the rams; 725 - 750 rpms. I Think that you mean the anti-stall unit; see Group 14 in the FSM, Fuel system for proper adjustment
60 dart
Posted 2014-09-19 4:59 PM (#456809 - in reply to #456797)
50002000100050010010010010025
sounds like the dash pot . test it to hold vacuum . if it doesn't , good luck finding a new one but i think it can be rebuilt for about 90$ if i remember correctly . i'm thinkin i was told about
the rebuild by jc restorations??? but i could be wrong . it was the guy that sells ram manifold elbow reproduction parts in the north west . a new one if found , expect to pay @ 300$ ----------------------later
58coupe
Posted 2014-09-20 12:02 PM (#456889 - in reply to #456797)
100050010010025
make sure you don't have a vacuum leak where the manifold bolts to the heads. This will cause a high idle and poor drivability.
GregCon
Posted 2014-09-20 12:19 PM (#456893 - in reply to #456797)
This is like a question right out of 1964....
Posted 2014-09-21 7:53 AM (#456948 - in reply to #456797)
Subject: RE: Ram Induction operation
Yep, Gerry just got teleported here from 1964.
Steve.
finsruskw
Posted 2014-09-21 9:11 AM (#456954 - in reply to #456797)
2000100100252525
Go through the entire adjustment process as described in the FSM starting with the accelerator pedal angle.
This is the only way to get these things to run right. You will need a short length of 3/16" rod to set the firewall bell-crank. I always use a short length of welding rod or brake tube for this.
The dash pot is not for adjusting the idle speed. If you mess with it, be sure and hold the pushrod while turning the adjusting screw or you will tear the diaphragm and the unit will be junk if it's not already.
The dash pot adjustment is the last thing you do and is to control the engine from stalling if it starts to loose vacuum while stopped w/ your foot on the brake and/or the A/C turned on. It's purpose is to momentarily "bump" up the idle to prevent a stall.
Chances are , if you do find an NOS unit, it will already be junk from a dried out diaphragm. I would be sure it holds vacuum BEFORE purchasing!! Ask me how I know this!! I got burned w/TWO of the darn things and had to have them both rebuilt.
Again, be sure to hold the push rod while turning the adjustment screw!!!
