Location: Klein, TX | Excess items for sale: Items probably fit other FL cars, but all items listed here were for my '57 Desoto Firesweep. The part numbers listed are from Gary Goers catalog. Prices listed do not include shipping. I am located in zip code 77379 which is just North of Houston, TX. Thanks, Bill
QTY P/N CONDX DESCRIPTION $ EA
1 133 NEW TRUNK LOCK GSK $1.00
1 5703 NEW GLASS POLISHING TOOL $24.00
1 CO405 NEW CERIUM OXIDE COMPOUND $5.00
2 190F NEW 1-1/2 BODY PLUG $0.75
2 190E NEW 1-1/4 BODY PLUG $0.70
1 66 NEW ROOF RAIL WX STRIP ENDS $10.00
4 101C NEW BRAKE BOOSTER HOSE CLAMP $0.50
6 101D NEW HEATER RETURN HOSE CLAMP $0.60
2 101E NEW P/S RETURN HOSE CLAMP $0.65
2 41A NEW PG. 21 HEATER DRAIN $4.00
2 41B NEW PG. 43 HEATER DRAIN $4.00
1 17A NEW PG. 9, DIVISION BAR UPPER CUSHION, PAIR $7.00
2 32 NEW PG.5, ASH TRAY SNUBBER $1.00
2 61 NEW PG. 9, VENT GLASS UPPER PIVOT GASKET $2.00
2 509 NEW PG. 13, SS SCREWS UPPER VENT WINDOW PIVOT $0.30
2 37 NEW PG. 9, LOWER DOOR HINGE SEAL $1.00
5 W106 NEW PG. 16, RUBBER EDGING FOR SPARE TIRE COVER $5.00
2 488 NEW PG. 16, TRUNK LID SNUBBER $1.50
1 NEW FT LEFT FLOOR PAN $60.00
1 NEW RT FRONT FLOOR PAN $60.00
1 USED GLASS FUEL BOWL ASSY. $12.00
1 USED STOCK OIL FILTER ASSY $20.00
1 NEW NOS MUFFLER $50.00
1 NEW NOS EXHAUST “Y” PIPE ASSY. $50.00
1 USED RT REAR HUB & DRUM ASSY $40.00
1 USED LEFT REAR HUB & DRUM ASSY $40.00
1 USED GENERATOR, Works $50.00
1 USED VOLTAGE REGULATOR, Works $20.00
1 USED CLOCK HOLE COVER PLATE $20.00
1 USED MAP LIGHT HOLE COVER PLATE $10.00
2 NEW STRUT ROD BUSHINGS $10.00
1 USED MEDALLION FOR HOOD '57 Desoto Firesweep $75.00
Edited by baker53 2014-08-22 9:23 PM
Location: Montreal, Canada | baker53 - 2014-08-22 2:28 PM
1 USED REAR SPEAKER GRILL INSERT $15.00
Sending you a PM about the rear speaker grille. | |
