Location: Pittsburgh, PA | [Thanks to Roger Hassel and Maria Svensson for translating the forums into Swedish!] If you'd like the forums to appear in Swedish, Danish, Dutch, French, German, Italian, Korean, Spanish or Russian, please go into the control panel and choose your language (all the way at the bottom). PLEASE NOTE: After you click submit, you will need to click submit a second time to change the language. Also, it is important to note that changing your language will not change the contents of any posts -- they will still be written in their original languages. Only the forum menus and instructions will change. If you'd like to help translate a language pack into your own language, just download the file you'll need to translate (attched below). The file looks like something like this: dictLanguage.add "GLOBAL-QUOTETEXT", "Random quote" dictLanguage.add "GLOBAL-YES", "Yes" dictLanguage.add "GLOBAL-NO", "No" dictLanguage.add "GLOBAL-ANONYMOUS", "Anonymous" dictLanguage.add "GLOBAL-STICKY", "Sticky" dictLanguage.add "GLOBAL-POLL", "Poll" dictLanguage.add "GLOBAL-CLOSED", "Frozen" dictLanguage.add "GLOBAL-QUOTE1", "Added by:"
You only have to translate the last part of each line, but there are about 5 pages of lines to transalate. If desired, I can also upload this language pack to the MegaBBS Main Forum so that others can benefit from your help!
Attachments ---------------- language-us.asp (77KB - 674 downloads)
