Location: atlanta | I'm gonna need a flywheel, thinking of going aluminum, I talked to Bob Walker and he uses aluminum and recommends them, any thoughts?
I have also been told that the flywheel/pressure plate and disk need to be balanced as a unit and marked so if they are ever removed, they can be reinstalled exactly as balanced, I assumed that these parts would be factory balanced, YES i used the word ASSUMED in the sentence. Any thoughts?
I also was surprised when the Poly 318 flywheel out of the 61 Plymouth turned out to be 172 tooth, which was only used on some early Hemi's.
Edited by fenix 2014-04-23 5:58 PM
