Floating power mounts
fenix
Posted 2014-04-18 4:12 PM (#436730)
Subject: Floating power mounts
2000100
OK, he's a dumb question for ya, when installed wihich way does the tang at the bottom face? I forgot and the SM shows no pic and assumes you aren't as stupid as Me, they assume wrong.
wbower3
Posted 2014-04-18 10:03 PM (#436764 - in reply to #436730)
Subject: Re: Floating power mounts
Walter passed away on Jul 29, 2014. We will miss you, Walt!
50001001001002525
It'd help to know what engine, front mount or rear mounts!
fenix
Posted 2014-04-18 11:15 PM (#436777 - in reply to #436730)
2000100
oh, front, the rear is also called a floating mount? the 318 poly mounts.
ttotired
Posted 2014-04-18 11:55 PM (#436785 - in reply to #436730)
50002000100010010010010025
This help?
(dodge 318 strip 004s.JPG)
Attachments dodge 318 strip 004s.JPG (103KB - 35 downloads)
fenix
Posted 2014-04-19 12:10 AM (#436786 - in reply to #436730)
2000100
Seems there's no reason to reverse them.
ttotired
Posted 2014-04-19 1:13 AM (#436789 - in reply to #436730)
I think if you put them on backwards the engine would hit the firewall?
You remember what holes in the frame to bolt them to?
fenix
Posted 2014-04-19 1:17 AM (#436791 - in reply to #436730)
2000100
I need an inch for the hemi, the poly is 17" from mount to bell and the hemi is is 16".
ttotired
Posted 2014-04-19 4:27 AM (#436804 - in reply to #436730)
Should work out
There should be 2 bolt holes for the mounts on the frame, the poly uses the front hole, so if you use the back hole, that should suft the engine 1" back so it meets the trans.
I havnt done a poly to hemi swap, but I think that should work
BigBlockMopar
Posted 2014-04-19 4:49 AM (#436811 - in reply to #436730)
20001000500252525
IMO, there are 2 variations to these mounts, depending on the wheelbase of the they are used in.
On a longwheelbase car the 'tabs' point to the front of the car. Reverse for a shortwheelbase car. But the mounting to the block stays the same.
At least that's what I can remember the last time I played with them on a car.
ttotired
Posted 2014-04-19 7:48 AM (#436817 - in reply to #436730)
Could very well be right there, the engine pic is the engine from my dodge phoenix when I took it out
